Here is the latest from Losi:
4" Threaded Rock Crawler Shock Set w/Springs (4)
At a Glance
Losi's 4” Rock Crawling Shock Set is specially designed for use with 1/10-scale rock crawling vehicles. The shock set features four hard-anodized aluminum threaded shock bodies with hard-anodized aluminum adjuster nuts for easier adjustments while on the rocks. An internal rubber o-ring in the adjuster nuts enable the nuts to maintain their positions under severe suspension articulation. The shock set comes with ultra smooth Ti-Nitride shock shafts, white shock springs, shock limiters and assembly hardware - just add the Losi Silicone Shock Oil of your choice.
Features
* Shock set features four hard-anodized aluminum threaded shock bodies with hard-anodized aluminum adjuster nuts
* Adjuster nuts feature an internal rubber o-ring to maintain their position under severe suspension articulation
* Shock set includes ultra smooth Ti-Nitride shock shafts, white shock springs, shock limiters and assembly hardware
LOSA5082
MSRP: $64.99
Available for*: $58.59
