Radio Control Zone » RC Car Action: Forums » General Vehicle Forums » Electric Vehicles » What would make truck drive slower (outside of battery)?
Electric Vehicles Discussion related to Electric On-Road and Off-Road Vehicles
Old 05-08-2012, 10:13 AM
tamping88 tamping88 is offline
I've noticed that the Torment we have is noticeably slower and at first thought it was something with the battery. But I dropped the Ni3800 into Jr's slash and it ran just fine. So it appears motor or drivetrain is issue. I had the slipper clutch set way out without a lot of tension, so gave it a turn and a half but there was no difference. Is this a sign the motor is already giving way? We've used the truck less than a month and on average we're outback every couple of days driving them.
thx
Old 05-09-2012, 01:30 AM
rccardude04's Avatar
rccardude04 rccardude04 is offline
When you say "noticeably slower," do you mean it's just less power than originally, or does it barely move under its own power? It's a little unclear as to what you mean.
If it's just an apparent performance degradation, I'd tend to blame the motor first; mainly due to overheating if the vehicle has been run in grass constantly, or more than one back to back.
If it barely moves under its own power, but sounds like something is spinning like it should, start by checking wheel pins, hexes, driveshafts, spur/slipper settings and tension (sounds like you did the slipper already but it can't hurt to make it good and snug, then back it back off to where if it was if there's no change), etc. Bad gears usually make horrible grinding noises so you're probably OK there.
Good luck! Post up with any other clarifications, questions or updates of success or failure!
