Nitro Vehicles Discussion related to Nitro On-Road and Off-Road Vehicles
Old 06-09-2002, 10:43 PM
Dave Scanavino
Guest
Posts: n/a
RC10 GT pulls left
On very hard acceleration when the front tires are lightly loaded the cars pulls to the left. On lighter acceleration there is no problem. It's like the left rear wheel pulls harder? Any thoughts? Dave
Old 06-09-2002, 11:01 PM
moorerc moorerc is offline
perhaps there is something up with your differential. I just ran my GT today, and it didin't pull left on hard acceleration. Maybe your steering to the left without realizing it. Just a thought.
Old 06-09-2002, 11:17 PM
Dave Scanavino
Guest
Posts: n/a
You could be right on the diff. I bought this used. It pulls when my son drives also. No fingers on the sterring wheel at all. Dave
Old 06-09-2002, 11:28 PM
StevePond's Avatar
StevePond StevePond is offline
It's usually related to a bad bearing on the left outdrive of the diff or a left axle bearing. I'll bet one of them has gone bad.
Old 06-10-2002, 10:52 AM
muddbogger muddbogger is offline
Banned
when i steer mine right the left tire comes off the ground like 2 inchs, but i turn it to the left the right tires dont lift.....thats the prb. here?
Thanx
Old 06-10-2002, 12:54 PM
jdm3849 jdm3849 is offline
maybe your diff. is unloading which is causing it to do that? try tightening it up a little bit,and make sure your ballstuds are all tight.
Old 06-10-2002, 04:56 PM
AEAddict AEAddict is offline
Also make sure your rear TOE is exact on both sides. An un-even toe-degree can cause erratic steering too (both front or rear settings)
