  #626
Old 01-12-2005, 08:04 PM
TRF Drive Hard's Avatar
TRF Drive Hard TRF Drive Hard is offline
RCCA Moderator
Genuine tamiya i say...
Old 01-12-2005, 09:15 PM
TurboFC3S TurboFC3S is offline
I'll probably give that suspension set a shot ... keep the Tamiya universals in a bag and source some titanium CVD's. When I find some that fit, I'll post where I found them. Fun stuff, I'm diggin the 02.
Old 01-12-2005, 10:16 PM
RCCA Moderator
The best you can get are the ti axle
Old 01-13-2005, 11:40 PM
Raceking Raceking is offline
Novak SS5800
Is the Novak SS5800 going to be ok on the stock TB-02 gear ratios? Or will I need to up/down the pinion size?
Old 01-14-2005, 12:00 AM
RCCA Moderator
Try the stock gearing first... should be ok with the BL...
Old 01-14-2005, 01:34 AM
Novak SS5800
THX TRFDrivehard
Old 01-14-2005, 08:45 PM
CrzyDrifter CrzyDrifter is offline
anybody hear anything about the tb02r? im goin to wait for TB02R instead of buying a tb02. for the time being, im gona play with my yokomo mr4tc sd black
Old 01-14-2005, 09:08 PM
RCCA Moderator
Youd think the SD is better than the tb02...
Old 01-14-2005, 09:15 PM
I'm building mine right now ... the SD seems stiffer and has a few more goodies than a TB02. Kit screws suck though, and the motor mount is kinda funky. Haven't built the suspension yet, should have it done later tonight.
Old 01-15-2005, 11:27 AM
microrcdude microrcdude is offline
Project Drift Club
Well, your building a drifter. Have you seen a drifters suspension? Its completely solid. Kinda like a tank.
Old 01-15-2005, 01:05 PM
Got it 95% done last night ... the suspension is fine except for the shocks not being oil filled, ***? Fortunately Yokomo sent me the Stage 1 and 2 upgrade kits, one of which has a nice set of aluminum oil filled shocks included. Also bad is metal bushings on the axles ... but I have replacement ceramic bearings I'll run it first in stock trim, and then try out the upgrade kits. After all the stuff I have to go on it, the car will be more hopped-up than the SD Racer kit.
Old 01-15-2005, 07:05 PM
Project Drift Club
Sweet! Now listen carefully: POST PICS
Old 01-15-2005, 07:15 PM
RCCA Moderator
Ya post pics of the SD in the SD thread!
Old 01-15-2005, 09:27 PM
wait? r u saying a sd black or ssg is worse den a normal mr4tc? wth? that does not make any sense at all. an sd black has so many more hop ups den a normal mr4tc.
Old 01-24-2005, 12:20 AM
versionpardner versionpardner is offline
the tb02r will be released feb 18th
Old 01-24-2005, 02:05 AM
with a 17t motor how should i gear the car? {spur/pinion**
Old 01-24-2005, 02:10 PM
The threaded GPM shocks fit good, and were only $20. They came with 3 different shock pistons, and different end ball-joints to adjust the shock length. They get rid of the stock ball ends though. Springs that come on them are pretty stiff, but Tamiya springs fit. They feel 100x better than the crappy plastic kit shocks.
Old 01-24-2005, 02:11 PM
GPM Shocks on Front ...
Old 01-24-2005, 02:41 PM
RCCA Moderator
Looks cool!
Old 01-24-2005, 09:17 PM
Ordered my Surikarn front and rear shock towers, aluminum motor mount, and sway bar set ... now what ways are there to stiffen this chassis up, it's way to bendy. Can you take the plastic piece off the front and rear of the tub upper (the parts covering the spur and shaft front), and use a EVO 3 carbon upper plate?
Old 01-25-2005, 04:48 AM
RCCA Moderator
Ack Ack!!! you got the tb02 aluminum motor mount right? im thinkin you got the evo3 version... im not sure about placing the upper carbon on it...im trying to visually look in my head lol...
Old 01-25-2005, 11:24 AM
No, I knew the Evo3 motor mount is different than the TB-02 ... I got the right one.
Come on TRF, I expect a difinitive answer from you in under 24 hours.
Old 01-25-2005, 05:53 PM
look at my car look it's soooooo nicehttp://forums.radiocontrolzone.com/attachment.php?attachmentid=52624&stc=1
Old 01-25-2005, 05:58 PM
more you sayhttp://forums.radiocontrolzone.com/attachment.php?attachmentid=52625&stc=1
Old 01-25-2005, 06:01 PM
and lookhttp://forums.radiocontrolzone.com/attachment.php?attachmentid=52626&stc=1
