09-27-2003, 05:41 PM
switch w/ charging jacks ?'s
hey, I am upgrading all my radio equipment and not using AA's anymore. my new set up has a switch with a charging jack. I have never used this type before. there are 2 male leds and one female lead. Know i know the female lead goes to the battery pack, but which male plug goes the the reciever??? and which one is the charger plug??? is the one next, and on the same side of the switch the charge plug or the one on the opposite side. thanx for your help.
09-28-2003, 09:33 AM
what radio do you have and what charger are you using.
09-28-2003, 11:46 AM
It makes no difference as to what radio he has, all charge switches are essentially the same.
One side of the switch has both the male and female connector and the other doesn't, right. Well just plug the battery into the female connector and take the male connector from the other side of the switch and plug that into your Rx. Now the male connector the is open on the battery side is the charge plug.
09-28-2003, 02:07 PM
AreCee -
Thanks bro.... I just wasn't sure as to which male end was the charging end. I appreciate your help.
09-28-2003, 10:04 PM
i was very interested in what radio he was using because i have not seen a radio charger like what he is explaining. airtronics, jr, hitec radios that i own only have a single female plug for the charger. why are you plugging into the receiver??
09-29-2003, 12:43 AM
I got a Lynx 3d, but i think you got confused along the way somewhere, arecee is correct i believe, and I also think the switch has to be on in order to charge if im not mistaking?
09-29-2003, 08:37 AM
No the switch should be in the off position. If you leave it in the on position your servos and receiver would drain the battery faster than the trickle charger can replenish it.
The Hitec harness also allows you to plug in the DSC (Direct Servo Control) cord and then you have to switch it on in order for the DSC to work.
09-29-2003, 06:30 PM
sorry for my confusion guys. until AreCee mentioned "DSC cable"
i did not have a clue what you guys were talking about. i have not used my dsc cable in a couple of years. i actually starting using the wall chargers for my radio batteries.
09-30-2003, 01:25 AM
you don't even need to use that part for charging, that part with the switch is to use the DSC and a Rx pack at the same time. all you need to do it plug the rx pack directly inot the charger, don't try to charge through your rx it might harm it
you can download a manual for the 3D from www.hitecrcd.com
09-30-2003, 01:41 AM
ok for onr thats not what i wanted to do.. u can charge thru the rx without harming it and i have the manual, it shows nothing on how to wire it up with the switch so.... but i have my answer and it works so.. thanx anyway
09-30-2003, 08:46 AM
The charging switch harness allows you to charge the Rx pack without removing or unplugging anything. It doesn't go through the receiver because it's on the other side of the switch, that's very basic electronics. You can't get current to flow through an open circuit and when the switch is in the OFF position then no current flows to the receiver only to the battery which is on the same side of the circuit.
09-30-2003, 11:28 AM
Agreed, I have one on my savage to do that, but if I remeber correctly the harness that comes with the 3D is not a charging switch harness. It allows both the DSC cord and the rx pack to be connected to the same slot on the rx.
Yeah, what he said......it took me a minute to figure it out but I understand it now. Thanx.
09-30-2003, 11:42 AM
ok I will clear up all doubts for you. I have this radio, and this is the exact replacement from HiTec to use the switch in the following link, which is a charging jack. but I had to ask to be sure on placement to double check, since the manual says nothing about it.
charging Jack
09-30-2003, 12:09 PM
This should clear up the confusion. The Hitec chargeing switch harness also doubles as the DSC because it has an extra wire in it, the yellow wire. This is the wire that carries the signal from the Tx to the Rx while the Tx is not transmitting. This works with the ground wire, the black one. When you use the DSC you are not using the red wire which is why you need to turn on the Rx.
The non-Hitec charge switch harness made by Futaba, Sanwa, JR, etc only use two wires, a red (power) and black (common). There is no yellow DSC wire.
I hope that clears things up a little.
09-30-2003, 12:12 PM
This is a standard charge jack switch harness and cannot be used with the Lynx and the DSC cord. You do not have the third wire to carry the signals to the receiver.
Hitec Part #54401 is the EXACT replacement, accept no substitutes.
