  #126
Old 01-08-2005, 04:30 PM
kurrz kurrz is offline
how fast is a TD with to 27 turn motors? thanks for the reply i finally finished mine last night waited two weeks for the radio to come but now theres snow on the ground so i just ran it in the basement one more question on the drivers side front one of the dogbones keeeps coming out so i put a small zip tie in the drive up anyways that dogbone is loose any suggestions thanks again
Old 01-08-2005, 10:12 PM
guver guver is offline
I think it is very slow, but indoors may seem fast (probly too fast) I would guess about 10 mph or more.
On the dogbone, I just got done building my second td and I remembered that I installed an extra o-ring on the outsidfe of the bone (just like on the inside)It is possible you forgot the oring?
I've ran my first truck nearly double speed as stock and never lost a dogbone, just keep loosening the wheel nuts. I can't seem to keep them tight.
Old 01-08-2005, 10:29 PM
thanks ill check out the oring thing i read somewhere when you wire motors in series the turns of the motors become additive ex: 12t+12t=24t is this true? if so a good esc would cost half as much as a super rooster and if i use 2 12t would that make good power and could i get decent run times with a good pack? thanks again
Old 01-08-2005, 10:30 PM
also on the wheel nuts maybe some weak thread locker
Old 01-08-2005, 11:02 PM
Yes, that is right about the motors. They will also have about half the power.
I've been using white out on the nuts, I probly will go to thread lock soon.
I had more fun with my td than I've had in a long time, my whole front yard was solid ice from the freezing rain. I could do full throttle power slides, spin-outs, donuts . I can see why people enjoy drifting, that's basically what was going on.....
I could get the truck to slide exactly straight side ways for over 30 feet.
Old 01-09-2005, 06:56 PM
why would the motors only have half power also what set up do you use the power sliding sounds awesome glad to see im not the only one into this truck still havent been able to go out side we got three or four more inches last night
Old 01-09-2005, 08:32 PM
When motors are wired in series, they are getting half the voltage. They pull far less amps. Not sure if it is exactly half though on the amps.
we got a few more inches too. stuck inside ...again.
Old 01-09-2005, 11:10 PM
oh ok i just get the super rooster then and wire the motors in parallel it sucks being stuck inside
Old 01-15-2005, 12:26 AM
I just finished my td. I did something pretty weird to help break in the motors. I always hook motors in series to break them in. When doing this on the td it acts like a center diff. Allowing the rears or fronts to spin faster or slower. Prety weird on the bench with the wheels off the ground.
Old 01-15-2005, 08:55 PM
sounds weird finally the snow melted enough to get a few runs in today at first i thiught i broke something the truck had a hard time taking off and it was making a spinning? noise then i realized the rims were spinning in the tires so i glued them its a pretty torquey truck cant wait to upgrade
Old 01-15-2005, 09:28 PM
shinna202 shinna202 is offline
i have TD it is pretty much stock excapt for the coustom chassic
it is nice and im on a project to make it cralwe
Old 01-15-2005, 09:45 PM
looks cool did you build the chassis if so nice job
Old 01-16-2005, 01:58 PM
i bulit it
Old 01-16-2005, 06:32 PM
cool whats your set up esc radio and so on where does the battery go? also like the paint job
Old 01-17-2005, 01:05 AM
well the ESC i cant remeber and in between the electronics but you cant see them because the pics are taken to low in order to see you have to look top to bottom
Old 01-18-2005, 10:56 PM
I just noticed I have 2 bent dogbones in front. Are there any slightly heavier duty ones?
I've never had them pop out.
Old 01-23-2005, 10:56 PM
DanWilliams DanWilliams is offline
TL01 parts for Detonator
Hey guys,
has anyone tried using the TL01 hop-up and aluminium after market parts on a detonator?
Are there other types of parts that can be used on the Det?
Old 02-01-2005, 02:31 PM
just ordered a super rooster and a set of team orion 15x2 adjustable timing motors should be putting it together this weekend also has anybodt used any aluminum stuff from r2-c2.com looks nice but is it rugged and high quality? any feedback appreciated
Old 02-02-2005, 02:51 PM
Wild trial Wild trial is offline
Just ordered socktowers for my car from r2-c2, have'nt got any yet.
Live in Norway so thats the reason.....
______________
The Norwegian Wild-Trail
Old 02-03-2005, 06:41 PM
well turns out the motors i got dont have adjustable timing so could i just reverse the positive and negative wires on the front motor and it would then turn in the right direction also will this hurt the motor or esc i am going to wire the motors in parallel thanks
Old 02-03-2005, 07:01 PM
It will reverse rotation, buut the timing will go negative (if it's 0 that's good) If it has timing then it is not good.
Old 02-03-2005, 07:02 PM
I just put 2 14 tuirns in mine, and for breakin I wired in series. It's kinda cool like haveing a center diff. Front end burn outs and will go around a corner pretty good too.
Old 02-03-2005, 09:35 PM
how could i find out what the timing is and could you reccomend some motors for it i may just buy some different motors i got these from tower on sale for 14 bucks a piece they are team orion rush motors
Old 02-04-2005, 06:15 AM
orion rush do have adjustable timing, the ones I have do.
Old 02-04-2005, 07:38 AM
the insrtuctions say they have adjustable timing, is it set at 0 degrees if not how do you set it at 0 degrees thanks
