03-14-2004, 01:40 PM
Attention Novak BL owners
Ok. I finally got my Novak SS system set up,when I turn everything on,the esc's blue light comes on solid,and the motor goes by itself really slow,and I've checked the throttle controls and everything..SOMEONE has to know whats going on.
03-14-2004, 06:53 PM
before you turn on push the set switch down until a red light comes on. then set your throttles again if that dont work in my opinion send it back in to novak for service. I kept mine for two days to be honest it was doing what your describing and I could not set it. Sometimes on occasin it would set, but then glitch after a big jump in my triple XXX. then all of a sudden it stopped setting and the motor just ran even when I tried to set it.
03-14-2004, 08:32 PM
cats
Cats, If I gotta send back this bl,Im gonna be so pissed. I hate sending back products,they should be sold ready to run in perfect condition. GOSH. I'll let you know what it does here,thanks.
03-14-2004, 09:58 PM
ok
Cats,I re-set it,and now it works..BUT..the reverse is acting like the forward..and the forward is acting like the reverse??
03-14-2004, 10:57 PM
If your forward and reverse are switched, then you went through the setup process a little backwards. Look:
Turn on Transmitter
Press, and hold, the set button
While holding the set button, turn the speed control ON.
Continue holding the set button until the RED LED turns SOLID red. Release the button immediately when this happens.
Pull transmitter throttle to FULL-ON position (full-forward) Hold it until the LED turns GREEN.
Immediately push throttle to FULL BRAKES. Hold until BLINKING GREEN.
Immediately return throttle to neutral. Wait until Amber, green, and red LEDs turn on SOLID, and then wait until only the red LED is on.
You're set and ready to go! Just follow the instructions above or in your manual. If it doesn't work, repeat the setup process. Most of the time you just didn't set it up properly. Hope you get that thing going!
03-15-2004, 02:45 AM
kool
Ok..Heres what I did..set it up like you said..switched the THROTTLE switch BACK TO Nutral after setting it up..and its working good it looks like..
03-15-2004, 01:59 PM
Awesome. Glad to see that you've got it running.
03-15-2004, 02:42 PM
Cats
Cats..Gonna put a pinion on today..and run it for the first time..Is it gonna fly?
03-18-2004, 04:57 PM
hey man, whoever is using my username, could you stop immediately! why don't you just get your own? please do not post any more, thank you
