Car Action World's Fastest RC Car Challenge! What car are you going to build to break the world speed record for RC cars?
Old 05-29-2011, 10:43 AM
Hard Case Hard Case is offline
The Road to 200 – Nic Case & Team Associated
Team Associated and Nic Case have been working on a special project the dubed “The Road to 200”. I think that with all the input of experienced & talented individuals, that the possibility of reaching 200mph with an R/C car is within reach.
This is the equipment we plan to make history with.
The car ,the SR11 is based on the NTC3 and is designed by myself and Curtis Husting.
Power is supplied by a 1521 Neu motor, 12 cell PowerEdge LiPo battery, and the sophisticated power management of a Castle Creations HV speed controller. The gears are the finest made 32 pitch hardened steel version by RW, while the radio will be the Fasst System from Futaba and the tires are from BSR.
N
Old 05-29-2011, 11:03 AM
Here is short teaser video
http://www.youtube.com/watch?v=OrwF1...layer_embedded
N
Old 05-29-2011, 11:23 AM
Video update
http://www.youtube.com/watch?v=Xiki9...el_video_title
http://www.teamassociated.com/road_to_200/
The guys at Team Associated have put together another professionally edified video. Just excellent !!!
Details of the car, products used & you can get a really get a glimpse of how hard this is.
My grammar needs improvement, LOL - you’ll see in the interview portion.
Anyway
Still working on the "last" parts for a June or July attempt.
N
Old 06-03-2011, 10:17 PM
TLracing TLracing is offline
That is insane. Car was flying and spinning in the end of video. LOL
Old 06-05-2011, 11:23 PM
ss13t ss13t is offline
He said he had a blow over at 175 but then at the end the end of the video the guy says it's the fastest rc in the world at 167??
Old 06-06-2011, 11:51 PM
Yes, you are right
Sorry for the confusion. This video was but together from two separate test sessions. One in December and the other in March. If you look and listen and even closer you will also notice "other" things that don’t really flow perfectly.
But, I do think this video communicates what we are trying to do with some decent footage under the hood......
As far as the blow-over, it happened at 177mph – we were actually lucky we got a reading ,since it happened after the speed traps. It has happened 3 times before -- just not with a speed-reading. The audio at the end, mentions 167mph that was from our first run, in the morning, not in the evening like the video implies. In between those two runs, we also had one at 173mph.
Anyway
Now that we have extra-long-range with our 4PK, next time out otta-be good.
N
Old 07-15-2011, 09:58 PM
Check out - The Road to 200, on Jalopnik !!!
LOL
http://jalopnik.com/5819056/worlds-f...-reach-200-mph
N
Old 07-19-2011, 01:03 AM
The New York Times
nuf said
http://wheels.blogs.nytimes.com/2011...p-h-super-car/
Cheers
N
Old 07-22-2011, 05:26 PM
JOHNNYMAXXIMA JOHNNYMAXXIMA is offline
Nice article Nic! Do we have a date for Fontana yet? Will you be attempting the 200 mark there?
Old 07-29-2011, 11:26 PM
Tc5100 Tc5100 is offline
I need help with my tc5 i want to break a 100 I reenforced the sides made plastic 90deg turns and velcrow to keep the body on I have a mamba monster max 2650kv I have a 60t pinnon and a 43t pinion I'll try org but what spur gear should I use I hear a 69 would work but just wanna get some advise from the pros lol I have a wing on the back of the body like vassmar pretty much the same as him but blue I have gpr foam tires on it but any advise will be appreciated
http://i166.photobucket.com/albums/u...270408_s17.jpg
Old 08-02-2011, 10:01 PM
Sounds like you're on the right track.
WOW -- that motor has monster torque ....
Can you give me a bit more information about your esc and cell count?
N
Old 08-02-2011, 10:12 PM
It's a 1/8 scale mamba monster max 2650 I have a 3cell 4000mah 11.1v battery but I don't know eBay gearing to use I just tried 69/60 gearing and only got to 62 then the tire fell of lol.. Luckily I didn't break anything but thursday or Friday I'm gonna go try again hopefully it doesn't rain but do u think I can hit 100 and do u have some ideas how I can make downforce find for thr front like vassmar i have th same body as him and a little bigger wing in the back but it doesn't seem to be handling the best but idk I'll keep you updated next time I run kt
Old 08-22-2011, 09:27 AM
Hi Tc5100
I’m sure you have read this;
http://iscspeedchallange.forumotion....car-go-100-mph
As far as going 100mph with your set-up, I’ve calculated that with that motor battery combo --- you will need to gear 49spur to a 69 pinion.
And get these tires………….
Gear
http://www3.towerhobbies.com/cgi-bin...?&I=LXYGN2&P=7
Tires
https://www.ssl-stormerhobbies.com/c...ns&pn=JAC3042P
But what I would do if I where you
Change the motor to a 7700 Kv MM
http://www.ebay.com/itm/Castle-1-10-...item1e64f154d9
Then gear it = 69 spur 33 pinion, much easier to gear + I think you could go even faster.................
Hope this helps
Cheers
N
Old 08-22-2011, 09:51 AM
So will the 49t spur bolt up on the tc5
Old 08-22-2011, 10:34 PM
Yes
N
Old 08-22-2011, 10:35 PM
BTW
what is your name?
N
Old 08-22-2011, 10:44 PM
Josh. I'll be ordering the gear and tires tomorrow might not get thr motor maybe in a couple of weeks but I'll get a speed run out when I get the gear
Old 08-23-2011, 07:43 AM
Cope57's Avatar
Cope57 Cope57 is offline
I hope that you get the speed run on video, I would love to see you break the 100 mph.
Computers do not have problems, they have users.
~Cope57
Old 08-23-2011, 09:45 AM
I'll try lol still have to work some issues with the steering it's got a little slopp in it. When you try and go it's all over
Old 08-24-2011, 08:43 AM
Hi Josh
With the steering I suggest tightening the "servo saver" collar all the way and add 1' tow-in to the front. Can you post a photo of the car with body on- and off?
Also---Turn down your dual-rate on the radio ,so when you drive the car slowly - with the wheel all the way to the left --it makes a 20-foot diameter circle. Then do the same to right - if different adjust end point on the radio. Re-trim the steering - and check it again. This is very important and often overlooked.
Cheers & good luck
N
Old 08-27-2011, 05:38 PM
We should continue this conversation on this thread:
http://forums.radiocontrolzone.com/s...d.php?t=261790
Team Associated speed running to 200 mph miles per hour -- is what this thread is about......
N
Old 10-08-2011, 06:13 PM
Chronicling - The Road to 200
If you have 4 minutes to spare,
I’ve just put together a video chronicling our journey to get an R/C car to achieve 200mph.
Even thought the goal has not yet been realized, I thought it would be good to honor the effort, time, & support of the 80+ people that have contributed over the last several years.
http://nic.smugmug.com/Cars/The-Road...2_4JqvSRX-A-LB
Cheers
N
Old 12-18-2011, 10:52 AM
Hey Guys
It's been a while, but here are two interesting videos you may be interested in.
https://www.youtube.com/watch?v=nPP3g0tgKUk
https://www.youtube.com/watch?v=JVRpYq12GTQ
Cheers
N
Old 12-26-2011, 11:43 AM
rccardude04's Avatar
rccardude04 rccardude04 is offline
Just out of curiousity, are you not running any kind of gyroscopic steering assistance on the car? Every gyro-assisted car I've had you can just kinda get it going the right way and it'll track like an arrow even if the terrain is less than perfect.
Great driving! I keep waiting for the 'mission accomplished' video.
Old 01-12-2012, 10:06 AM
ironoutlaw's Avatar
ironoutlaw ironoutlaw is offline
very cool , im courious what is the fastest speed for a stock chassis car and a stock body ? with modifications of course
www.nolimitrcofmi.com
