Old 09-19-2004, 06:36 PM
Hockeekidd98 Hockeekidd98 is offline
rs4 rtr3 evo
Hey, i want to make my evo sort a rally car. meaning i wanna be able to take it into the dirt and street.
No jumps really,just a flat dirt track.. I 'm gonna need a higher ground clearance, new tires, rims, and suspension? Links?
Old 09-19-2004, 07:21 PM
josh222's Avatar
josh222 josh222 is offline
Eric got banned :P
I converted mine to Rally and it had a whole 1" clearence. I filled the suspention down to get rid of the limiters. I also made some mounts to lower the shock postion...here is a pic Rally pic
Old 09-19-2004, 08:17 PM
"filled the suspension"???
Old 09-19-2004, 09:11 PM
josh222's Avatar
Eric got banned :P
I filed the c-hubs, sorry for that typo
Old 09-19-2004, 10:00 PM
I'm sort of a begginer, so I don't know what they are or where they are. explain?
Old 09-19-2004, 11:35 PM
trw trw is offline
The C-hubs are what the front steering blocks are attatched to...its shaped like a "C" and attatches to the A-arm and also houses the steering blocks, the steering block is what allows the wheels to turn.
Old 09-19-2004, 11:55 PM
Can you post a picture showing it? I'm still lost, lol.
Old 09-20-2004, 12:45 AM
trw trw is offline
this is what the C-hub looks like...located only on the front wheels...the turnbuckles attatch to the top of it and the bottom is attatched to the A-arm.
Old 09-20-2004, 07:53 AM
josh222's Avatar
Eric got banned :P
You have to get rid of the nub on the side and thin the whole thing up and also cut a little out of the back of the arm so you can have a lot of movement
Old 09-20-2004, 07:58 AM
always_opencarb always_opencarb is offline
you could get a tc3 and a rally kit or extend the wheelbase, add longer shock shafts, get new wheels,tires,and a new body and it should work
Old 09-20-2004, 09:06 AM
Can some one give me a tutorial on this or link me to the parts. I'm kinda new to this so I don't understand everything you're telling me.
Old 09-20-2004, 11:27 AM
josh222's Avatar
Eric got banned :P
Your Evo isvery easy to convert rally. I converted my SS easliy.
What you should get....
Rally tires....HPI Rally Tires Soft
Shocks....Evader ST Shocks
Then file down the suspention so that it can drop down
Old 09-20-2004, 05:13 PM
Thanks for being patient with me
Few more questions. Would i Need this also?
And what would I use for front shocks?
Can you show me on the diagram what i would need to file down.
Old 09-20-2004, 05:59 PM
josh222's Avatar
Eric got banned :P
use those shocks front and rear and yes you need spring and oil, try a 30WT
here is a pic
All the parts circled you should file down also you have to file the back of the arm where the c-hub is against
Old 09-20-2004, 07:28 PM
I'm getting frustrated because when I look at my car and your diagram the things your telling me to shave make no sense.
Old 09-20-2004, 08:11 PM
josh222's Avatar
Eric got banned :P
ok here is a pic
Old 09-20-2004, 08:15 PM
josh222's Avatar
Eric got banned :P
here is a better pic, sorry...
Old 09-20-2004, 08:27 PM
In the bigger pic can you circle what needs to be sanded.
Old 09-20-2004, 09:57 PM
josh222's Avatar
Eric got banned :P
that is a Sanded one, i will have pic on tuesday of what it should look like with Nitro MT Shocks and Shock Towers, plus sanded suspention
Old 09-20-2004, 10:12 PM
Great, I really appreciate all of your help.
Old 09-20-2004, 10:35 PM
OK so I need the following:
(2)http://www2.towerhobbies.com/cgi-bin...?&I=LXAMU9&P=M
(2)http://www2.towerhobbies.com/cgi-bin...?&I=LXM976&P=7
(1)http://www2.towerhobbies.com/cgi-bin...?&I=LX3299&P=M
(2)http://www2.towerhobbies.com/cgi-bin...?&I=LXAML2&P=V
Anything else?
And can you edit the last pic to show me were you filed them down...lol i'm sorry im still kinda lost lmao.
But i'm really appreciative of your help.
Old 09-21-2004, 08:01 AM
josh222's Avatar
Eric got banned :P
Ok here is what you need to turn your Evo into a Nitro Rally....
Nitro MT Arms Front And Rear
NitroMT Shock Towers
Nitro MT Shocks
Super Nitro Rally Tires And rims
Super Nitro Rally body
MT Drive shafts
Nitro MT Turnbuckles
I Have turned my SS into a Nitro MT so i have most of these parts... I have found that the Nitro 3 Rally converted works but it is kinda tipy, turning it in to a Nitro Rally will make it wider. All those parts will cost about 70bucks but then you will have a good rally car and also have a Super Rally car aswell. If i get Rally tires and body i will have a Super Rally Nitro MT and a SS
Old 09-21-2004, 02:12 PM
Nitro MT Shocks
MT Drive shafts
70?? All those parts are way over 150.... What happend to the first way withthe evader springs and such... That was alot cheaper.every thing i needed that way came to 60.
Old 09-21-2004, 03:39 PM
josh222's Avatar
Eric got banned :P
It isn't that much....
Super Nitro Rally Arms 4.99x2=$10
Super Nitro Rally Drive Shafts5.29x2=10.60
Nitro MT Shock Towers 6.69
HPI Sport Shock Complete 15.99x2=32
Tunbuckles-6
grand total $66, just pic your tires and body
Or the cheap whey...
Nitro MT shock Towers$6.69
HPI sport Shockx2 $32for both
Rally tires about $10 for 2
Old 09-21-2004, 07:04 PM
Can you link me to the turn buckles, i can't find them.
