12-10-2004, 01:19 PM
Never say never (nitro)
I said i would never go back to nitro, but i have an itch.
All my boats are over 4' long and i want to try something a little different. After seeing all these new little .12 and .15 pullstart models I want to build something smaller.
I would like to make a little hydro like the old tether boats with the .049 cox engines except use the new smaller rc equiptment and a flex drive.
(something other than dumas' deep vee 10)
this is not for performance, just a cheap way to get through the winter.
is anyone currently producing anything like this?
a little 12"-15" round nose hydro.
if anyone has an old boat like this or the old hardware i would be interested in purchasing it.
Kevin
12-11-2004, 12:51 AM
Check out Climate Boatworks. Peter has some boats that could be easily adapted to nitro power. http://www.climateboatworks.bizland.com/ . If you'd like to scratch build, try www.microhydros.com for plans.
Finding something that small is going to be a challenge otherwise plus you'd have to run it in almost dead calm water.
to use an engine that small, you might want to use a Norvel motor, they have them with large heat-sink heads that would get you around having to run a water cooling system.
12-29-2004, 11:03 AM
Its getting together.
That micro hydro site is nice. I am 80% done building a hydro (hydromite), just under 14".
I have an OK Cub .049 with pullstarter, (I have a cooling clamp, but it is heavier than the engine) I'm making the hardware. I also got a nice little hitec micro servo. I'll try to get some pictures soon.
This boat fits inside my gas boats
-Kevin
12-30-2004, 10:46 AM
Does anyone know the average CG on a hydro?
12-30-2004, 12:42 PM
On a 1/8th scale boat, the CG is normally between 1" and 2" behing the sponson transom. Figuring the average length at 43", you're probably looking at 1/4 to 1/2 inch behind the sponson. Also, try to keep the prop weight at 1/2 pound or slightly less.
12-31-2004, 09:54 AM
I took a pic of the hydro, and the large big block engine.
So far this little adventure has cost me $12.
Engine
12-31-2004, 01:55 PM
lol i have one of those lil cox engines for a plane thats controlled with a string never got it running cuz the design of the plane made it hard to turn the prop with a stick
01-07-2005, 11:08 AM
more pics
This is sitting on my crackerbox
01-07-2005, 11:09 AM
Another view, fresh paint
01-07-2005, 11:10 AM
The electris are a tight fit.
batteries will be on either side of the engine, to adjust CG.
01-07-2005, 11:19 AM
Man, that´s small!
