07-26-2005, 02:30 PM
Miss Bud Flex shaft
Im having a problem removing the flex shaft from my 1/12 miss bud, i have loosened the collet nut and removed the prop shaft, but the flex shaft won't budge. does anyone have any suggestions???
07-26-2005, 06:32 PM
Also is there something else i have to loosen. Any help would be great i want to get it up and running
07-26-2005, 11:14 PM
There shouldn't be. Anything in the owners manual on it? Does that have the set screw in the collet?
07-27-2005, 05:24 AM
Rusted
The Ms.Bud I had didn't use a flex shaft it was a straight steel rod. If you haven't removed it it is more than likley rusted in the tube. I had to order a new shaft from the manufacture and all three they send me were rusted to the shaft when they arrived as well.
I allowed them to soak in a bath of WD-40 for a day and was able to get one of them to break loose. With the one still in the boat take a peice of water line or fuel line put it over the outer tube in the rear of the boat seal it with a nylon tie about a 6 inch peice. stand the boat on it's front end and fill the line with WD-40 let it sit for a day. Hopefully it will work it's way through the rust. If not you will have to replace the shaft and log and I would suggest you call the folks at proboat to verify the one they send you is not already rusted solid it took 3 different shipments for me to get one that was not rusted.
This is one of many reasons my Ms. bud is an X boat.
07-27-2005, 01:51 PM
No it is the flex shaft im 100% sure on that. I did everything the manual says and the shaft won't budge and it spins freely when i turn the engine over, im completely stumped
07-27-2005, 04:30 PM
I just put some WD40 on the rod where it is held in by the collet and she finally came out, Thanks for the help anyways
