Old 02-04-2006, 04:44 PM
julian julian is offline
RC10GT Differential?
I have a RC10GT, I took apart the tranny cause it felt rough when i turned the wheels by hand, i cleaned it up and put it back together and it is much smoother know, but the differential screw keeps coming loose any ideas?
Old 02-04-2006, 04:51 PM
evaderstman's Avatar
evaderstman evaderstman is offline
A new lock nut, and thread locking it will fix your problem.
Old 02-04-2006, 04:54 PM
differrential
also how tight does the differential have to be
Old 02-04-2006, 05:24 PM
pleaseletmeon34's Avatar
pleaseletmeon34 pleaseletmeon34 is offline
It's been a while since I've had my GT apart, but I'd say you installed the diff. gear wrong. It matters which side the screw is on (left or right and will fit either way). If you install it wrong it will unscrew itself. You don't want to put threadlock on it, and shouldn't have to.
Everything should be in your manual. If you don't have it you can go to Assoc. site and download it.
Old 02-05-2006, 12:26 AM
Checked my other GT and the bolt goes in the the spur gear side, so i had it right, thightened the bolt back up ran fine for about 5 mins, then came back loose, i don't know just going to buy all new hardware i guess.
Old 02-05-2006, 02:37 AM
Strange.. what your describing is exactly what happens when it is installed wrong. But your right, the bolt goes in from the right (spur gear side). As for how tight it should be. Tighten it till the "T" nut on the other side comes to the end of the dog-bone slot (the spring should be fully compressed), then back it off an 1/8 of a turn. Thats it.
Old 02-05-2006, 01:43 PM
there it is, there was no spring on mine when i took it apart, could that be the problem, i didn't realize it needed one as this is the first time i had one apart.
Old 02-05-2006, 02:22 PM
Well, you should download the manual. Even with slow dial-up its about 8-10 minutes. Associated is pretty good, lot of pictures and exploded views. You will see exactly how it goes together.
Old 02-07-2006, 01:27 PM
anyone have a link.
Old 02-07-2006, 01:32 PM
So when i get it put together, if it pulls left or right what do i do, except make sure the rims are evenly tight and the steering is straght. Do i loosen or tighen the diff bolt depending on which way it pulls.
Old 02-07-2006, 02:00 PM
rocknbil rocknbil is offline
Been watching, it indeed sounds like you had it on the wrong side. Are you sure you didn't leave out any washers, spacers, got all 6 thrust ball bearings in place?
Tighten it down tight, but not enough to break it, then back off 1/8-1/4 turn. This is very important. I usually do little "wiggles" as I tighten it back and forth until I can feel it's as tight as it will go without breaking the bolt or slipping off, rotating it by the other wheel in between each time to make sure it's seated. Now back off 1/8 turn. If this is not right, the balls will slip on the diff rings and dig a groove, frying the diff rings. They are supposed to ROLL on the rings, not slip. In extreme cases it can melt the diff gear, which is a GOOD REASON to use some slipper clutch! I use 1/8 turn back-off.
By the way next time you open the case, try flippng the diff rings over, it's almost like having new ones. You're supposed to put the side with the curved edge toward the balls, but if the rings have a groove, flip 'em over.
anyone have a link
Duh
Team Associated. I gave you the link to the page because there's several, part 1 and 2 and parts lists.
You don't do JACK to the diff. Leave it at that setting above. First, turn on your electronics and center the steering trim, and give it a good push on level concrete. If it doesn't roll straight, adjust the steering by the turnbuckles and servo control arm until it does. Wiggle the front wheels. If they swing more than 1/8" in either direction, you have some slop in the front end you need to sort out.
Now that the front end's right, it's normal for it to pull **A LITTLE** to one side on hard acceleration, especially with a big engine, but it should level out wthin a few feet. If it doesn't, you have something binding. Usually this is from leaving out the cone washers (SEE MANUAL) at the wheels, these are to keep the wheel against the bearings. There should be no binding on either side.
If it gets a little sideways on hard accel. from a dead stop, try loosening the slipper clutch just a little. This will help.
