Old 04-21-2006, 08:39 PM
alexanderevader alexanderevader is offline
7 cells in an evader?
I was was wandering if i could put 7 cells in my evader bx pro
i run a 9 turn double cobalt with gp3300cells any help would be
appreciated
Old 04-21-2006, 10:41 PM
RCnick RCnick is offline
Are you asking if it will fit?? If so then yes but you have to take the styrafoam block out.
Old 04-22-2006, 01:06 AM
yes but will i have to do any more mods
Old 04-22-2006, 07:24 AM
guver guver is offline
You may have to gear down, but the 9 turn will be close to overspeed. It will work for a shorter duration than with 6 cells.
Old 04-22-2006, 09:35 PM
you're saying that the motor wont last as long or the batteries wont last as lon?
Old 04-22-2006, 11:24 PM
Niether one. Both, you know what I mean rught?
Old 04-23-2006, 12:21 AM
both motor and battery life will be shortened or run times will be shortened
Old 04-23-2006, 04:00 AM
Helgaiden Helgaiden is offline
battery run time shortened, motor life shortened. Your still using brushes and putting that much power through a brushed motor costs alot in maintenance.
Old 04-23-2006, 04:01 PM
hey thanks for all the input i understand it now i just need to get brushless with lipo
batteries that should cure my problem any suggestions on what brushless to get??
