07-17-2006, 08:51 PM
Acadamey Triton 700SC PIKS*
Here is my fathers triton which he put the 700 sc motor, jeti esc and has 2 7 cells on the way. Any input or ideas? Its pretty quick
07-17-2006, 08:53 PM
another1
07-17-2006, 08:57 PM
a couple of ideas for ya...i'd start by losing the tamiya connectors. they don't like to have a lot of amps pulled through them. i would suggest you switch to deans or BK type connectors. you can shed a little weight by getting a different rx battery pack. look at cheapbatterypacks.com. you can get some kan350's, they are smaller and lighter, and best of all rechargeable (a 5 cell pack would be best). they are also cheap enough that you can get 2 or 3 packs, that way while you can run while you charge the spares.
07-17-2006, 10:40 PM
cool thanks
07-17-2006, 10:58 PM
ANy prop ideas?
07-18-2006, 07:46 AM
how big is the boat and how many cells are you running? are you running a flex drive or straight shaft (flex i hope). once we know that, we can start pointing you towards the right props.
07-18-2006, 11:43 AM
the boat is 30 inches long and it has a straight shaft for now.
07-18-2006, 05:59 PM
i have a ujoint in front and back
08-11-2006, 02:56 PM
Hi
I have the same boat and have just got a Graupner 700bb turbo to put into it.
I want to run two 7.2v battery packs but am concerned that the esc will blow up or melt. Anyone recommend an esc that can handle it or any other ideas. thx
I like the engine mounting plate you built for it - may try and copy that mate.
thankyou
08-11-2006, 05:15 PM
the jeti navy esc will handle that setup well. find it at offshoreelectrics.com.
08-11-2006, 10:50 PM
Looks like it's running pretty wet in that second pic. Might want to play with the COG. For a boat that small you could probably put a 48mm CF prop on that thing with no problem.
08-12-2006, 07:40 PM
as newjerseyjoe said, a Jeti ESC will be great. i have the Jeti 600 in my LSH boat and i love it. it was 85 degrees outside, and after 7 laps my controller was only 99degrees! i know of at least one brand that gets A LOT hotter than that (other boats of similar setup had 20-30degree hotter temps than mine)...but for some reason people keep using them. it is also smaller and lighter than most other ESC's.
08-19-2006, 10:31 PM
I am finding 700's like an x642 with 14 cells.
Harry
08-21-2006, 11:53 AM
08-21-2006, 08:07 PM
Hi zapco, in the fifth photo,did you notice that this Thai offshore Cat is carrying white powder? I must report to the Maiami VIce. Just kidding.  Awesome graphics!  I dig the skull but I wonder what that white thing in plastic bag is.....
08-21-2006, 08:53 PM
the bag looks like a very well protected rx. you can see the wires coming out.
08-21-2006, 11:46 PM
hey..guys don't put me in jail, the white powder was hinden place!! ("  yeah, right RX was in the tissue wrap and plastic bag again. very safe if u don't mind it looks fat!
08-22-2006, 01:45 AM
No worries mate, you did good job disguising it...
08-22-2006, 07:18 AM
Hey Zapco Nice triton . What kind of motor and esc are you using ? Also what kind of batteries?
08-22-2006, 01:31 PM
feigao 540 8XL
esc rooster 70
GP 3300 - 12 cell
08-22-2006, 01:40 PM
typo: feigao 540 6XL
08-22-2006, 05:39 PM
where do i get one of those esc's
08-22-2006, 07:16 PM
Typographical Error ?
Well a 8XL with a y535 prop looks quick on 12 cells.
But a 6XL on 12, what prop is in that photo ?
Harry
08-23-2006, 12:30 AM
Old Sloppy: prather s215
newjersyJoe: This is a modified version from BoatAhoy racing team in Thailand and if you are interesting to try this you can reach them at narade@ksc.th.com
08-24-2006, 07:20 AM
Hi - a few pics of my triton.
Just installed the new motor - went out to test it yesterday and the watercooled esc had a leak somewhere inside it and fryed the circuitry
Anyways got it replaced - hopefully will run it again soon to see how it goes.
looking to run it with two 7.2v powerpacks in series - reckon i might have to put the trimtabs back on? we'll see.
triton
