Old 11-25-2006, 12:55 PM
IRELAND IRELAND is offline
Teeth!
is it better to have more/less teeth on the spur
and what about the teeth amount on the bell?
i want a little bit more acceleration
Old 11-25-2006, 12:59 PM
bigmike216 bigmike216 is offline
If you want more acceleration, either go larger on the spur gear, or smaller on the clutchbell, or both.
Old 11-25-2006, 01:24 PM
xfusion xfusion is offline
Higher acceleration = slower top speed
faster top speed = slower acceleration (unless you get more power)
If you want faster acceleration, get yourself a spur with more teeth. I think that's what bigmike meant to say because the size of the spur generally stays the same. And Yes, of course you can change up your clutch bell gear with one with less teeth. Maybe beef of your nitro mix using like 25-30% and use the same config.
Old 11-25-2006, 01:32 PM
blktransam blktransam is offline
[QUOTE]I think that's what bigmike meant to say because the size of the spur generally stays the same
how can the spur gear stay the "same" size if it has "more" teeth?...
