01-21-2007, 02:11 AM
Bad compression but high speed?
I'm trying to figure out whether my engine has bad compression. Is it possible to have bad compression but still be able to drive a high speeds? I can start the engine, do 1-2 high speed passes, then the engine cuts out. Then it refuses to start back up. Can this be because of bad compression? Thanks.
01-21-2007, 02:41 AM
Sounds like your running lean and over heating or some other tuning related problem.
01-21-2007, 10:16 AM
Eric got banned :P
If your motor has little compression what could be happening is your motor warms up, internals expand and theres just not enough compression to run after that.
01-21-2007, 11:45 AM
^^ thats sounds more likely.....
01-21-2007, 01:59 PM
Can you turn the engine over with one finger?
01-21-2007, 02:08 PM
^^^ Adding to that, Can you turn the engine over with one finger quite easily?
01-21-2007, 04:49 PM
I can turn the engine over fairly easily with one finger. I have another engine that runs good, but that turns over almost as easily. I can't open up the engine and check because the person I got it from, he installed an aftermarket head and that thing is on tight, i can't unscrew it. I'm definitely not overheating, the engine never even gets near 200 degrees. It dies instantly, not like it's bogging down or anything. I sealed the engine with rtv silicone thinking it might be an airleak, but that didn't help. Oh yeah, installed a brand new glow plug too.
01-21-2007, 06:22 PM
Time for a new piston and sleave. That is typical when that happens. It's going to get worse if you don't change the P/S or have the sleave pinched.
01-21-2007, 06:37 PM
just wondering, but i cant turn the engine over with one finger...is this good?
01-21-2007, 08:16 PM
Jayboy, your motor is good.
01-22-2007, 12:33 PM
Well, I pulled the engine and removed the parts that can be reused. Since the cooling head won't come off, I have a nice looking paperweight now.
01-22-2007, 12:48 PM
Heat the motor up and then try to loosen the screws from the block. Use a heat gun or a hair dryer to heat the motor block. Just be careful when you handle the engine after heating. The heat will expand the metal and the screws will loosen up.
