07-21-2009, 08:27 PM
Originally Posted by henryj
Hey Kilruf, is the throw down charity race still gonna happen on 9-12. Lmk.
YES! "Throw Down" is ON! Got some travelers planning to attend and lots of sponsors and there will be at least one TC kit and a lot of door prizes given away at this event. Hope to see ya there!
07-21-2009, 11:14 PM
Saweeeeeet!
Glenn
07-22-2009, 09:41 AM
Originally Posted by varacer
Here are a few quick tips for racing cap tires.
You can treat tires with GM or Chrysler top engine cleaner. Coat the tires and wipe with rag and let sit. It helps to use a heat gun and pre-heat tires before going on the track. With heat in the tires you will not be as loose the first couple laps.
With using the above tire traction, it will continue to soften the tires. Depending on heat, track bite, you might want to switch over to something less aggressive after a few runs. Ie stick-et, which Glenn can order.
Oval racing on a large track does not or should not require alot of steering.
Most at easley are running the wings mounted on the body.
Hope this helps
Thanks for the tire tips. Plan on running 09 this weekend. You recommend mounting the wing on the body and don't see how this can be done on an 09 body?
P
07-22-2009, 10:20 AM
Paul-
I think that may have been for the electric cars. With gas as far as I know you have to go to the pod. I could be wrong though (it has happened before).
I would think at first you will want max grip. Bi-level wing mounted to the pod for .09 and then adjust from there.
07-22-2009, 10:34 AM
07-22-2009, 10:42 AM
There Is Plenty Of Room To Mount On Body On The 09. We Have Ran Them Both Ways On The Gas Cars Through The Years. The Body Seems To Be The Best Bet.
07-22-2009, 11:08 AM
James
I am still alittle fuzzy on how to mount on body?? I have a set of dark side window mounts, do you try to offset the mount away from the hole for the ignitor and offset the wing in the opposite direction?
P
07-22-2009, 11:13 AM
Can someone tell how to check replys I am getting Emailed to me?
07-22-2009, 11:50 AM
Click On "private Messages" At Top Of Page Under User Name.
P
yes you can mount the wing on the back glass of the body or the pod ive done both i agree with james i think it will be best on the body even though the only body i got right now is mounted on the pod
07-22-2009, 11:51 AM
Paul, I Never Used Those Mounts, I Still Use The 4 Buttons, So Im Not Sure. I Would Have To See It.
07-22-2009, 11:53 AM
hey james
07-22-2009, 11:54 AM
darn just missed you
07-22-2009, 01:03 PM
James
P
Paul you can use the Darkside mounts. You will have to offset them because the opening in the window for the motor head.
Be sure to offset them enough to not hit the head when they move. Mount one close to the Ridge in the window and space the other out equally to the other side.
07-22-2009, 07:29 PM
Larry
Thanks for information
Paul
07-22-2009, 09:33 PM
Certified Nutcase!
Is that SWEET for Christine?? I think I remember the guy telling me it is actually a '59 Plymouth.
This ones got a 383 Magnum
Do, or do not. There is no try!
07-22-2009, 09:45 PM
You can run on the body for sure. Either way will work. pod or body. If you mount the wing on the body just make sure the left mount is moved over to the left enough to clear head when the pod moves. Unless it looks like rain, I am coming saturday after work. I hope to maybe run the last qual in .09.
gary
07-22-2009, 09:48 PM
ksg wing mounts work great also
07-22-2009, 10:19 PM
Is anybody coming to run nitro late model (Barn rules)?
07-22-2009, 10:36 PM
Just to let everyone know,
The new updated website for Glenn's Hobby Corner is very near completion, along with a new racing home page that is dedicated to the track and the racing events held at Rosewood. All that needs to be done now is to go over some of the details about content on the site with Glenn and it will be online for everyone to view and use.
I have viewed it on a private host site and it is awesome. The work that went into the site, and the quality that was produced from this is jaw dropping. Sarah did a great job writing the HTML script and java apps. The site is going to have some really neat user interface. I can't wait till it goes online
07-22-2009, 11:32 PM
im finally back to sociaty (nc) is any one running legends dis weekend
07-23-2009, 09:04 AM
hey everyone guess what my touring car finally came in!!!! watch out sat.
07-23-2009, 09:07 AM
WHAT IS THIS, you must already know im going to beat you this weekend in e-truck so your going to legends
07-23-2009, 09:12 AM
does anyone want to buy my friends rc car stuff hes getting out of it
hes got.............a pan car ( i think a L4 only ran like 2 times),2 legend cars both RTR, and 2 or 3 mini sliders, a super brain charger a few 4-cells and some tools and a box..........he wants to sell it all for $200
07-23-2009, 09:32 AM
no that was so you wouldnt run over my car on purpose if i spin
(dat why im racin legends jk im still runin etruck
