Short Course Trucks Discussion related to RC's hottest segment, short course. Discuss any forms of short course trucks here.
Old 07-16-2010, 04:48 AM
Kuldeep's Avatar
Kuldeep Kuldeep is offline
PC Case Fans
How do I rig a case fan to work in a slash, as far as connecting, and how does it impact battery life, or should they have there own power-source?
I have this 80mm fan that pushes over 80CFM and I have a 40mm fan that pushes 25CFM.
Old 07-16-2010, 08:38 AM
rccardude04's Avatar
3.14159265358979323846264
I bet you could run it straight into your 3s lipo.
I've never tried it but I assume they're normally run off the 12v rail on a pc power supply. The peak voltage on a 3s lipo is 12.6 volts, so it should work just fine.
Just be sure to unplug the fan when you're done or you'll have a ruined battery.
-Eric
Old 07-16-2010, 10:07 AM
Lille Buller Lille Buller is offline
Or hook it up to the power cirquit after the swithc..
Old 07-16-2010, 03:27 PM
Kuldeep's Avatar
You know what, ill run its own power setup. I'll use a small 3s lipo battery just to power both fans.
How would the wiring scheme look, if I were to hook it up to the main battery?
Old 07-16-2010, 04:19 PM
No real clue honnestly.
Lol, hook them to yuor motor wires, more speed = more heat = more power to the fans :P
Old 07-16-2010, 05:37 PM
Kuldeep's Avatar
Hahaha that's a awesome, I think i'll do that.
Old 07-16-2010, 07:13 PM
hijacker's Avatar
hijacker hijacker is offline
www.airbornfx.com
Are you trying to turn it into a hover craft?
If it gets so hot you need a pc fan you might just be over geared.
Old 07-16-2010, 11:44 PM
If your gearing is right, you don't need a fan anyway.
If you really want one, keep it simple.
I'd just wire + to battery + and - to battery -.
-Eric
Old 07-17-2010, 12:19 AM
Kuldeep's Avatar
I go overboard when getting my stuff set up. Cooling goes all over the place. You guys should see my prize desktop computer.
I want to keep my motor as cool as possible and if it means putting a fan on it then thats COOL* lol
Old 07-17-2010, 06:27 AM
To optimaze the cooling effect you should make an air duct from the fan and wrap it around the motor with as much exit room as posisible.
If the cross section of free flowing air at the motor is about 50% of the the fan area that should up the air speed by 30-40% giving more cooling effect.
Known as the venturi effect.
Old 07-18-2010, 04:56 AM
Kuldeep's Avatar
Yeah some dude did that, I think it was on youtube, he had this whole ducted slash body. Pretty cool.
Old 07-18-2010, 06:42 AM
But hard to pull of iŽd think..
Old 07-18-2010, 08:36 AM
ducati777 ducati777 is online now
Where you get power depends on the fan. If its 12v, go straight from battery. If its a 6v fan, get power from the fan port on the velineon, or any open receiver channel.
Traxxas ERBE, 2Slash, XO-1, Associated SC10FT... and a Frog.
http://www.youtube.com/user/zaviac778
Old 07-18-2010, 01:13 PM
Good to know
