Radio Control Zone » RC Car Action: Forums » RC Car Action » Hot News and New Stuff Forum Cars, Trucks, Boats » Novak Crusher 2S-4S ESC & New Rock Crawling Systems
Old 08-02-2013, 11:53 AM
Chilly Duncan's Avatar
Online News Editor
Latest from Novak:
The Crusher was born out of the need to fill the gap of a single multi-functional speed control that could accommodate a multitude of applications -- rock crawlers, rock racers, short course, and even the heavy-duty RC applications that have no category! The Novak Crusher 2S, 3S, and 4S-rated, sensor-based brushless ESC fills that gap, and provides amazing power, response and speed at your fingertips. With auto-detect LiPo sensing and complete onboard programming, the Crusher brings a new level of user-friendly operation and on-the-spot adjustability. The Crusher is wired and ready to install. It includes a replaceable receiver harness, a full coverage heat sink, cooling fan, and its sealed case design means the Crusher is ready to rock right out of the box!
CRAWLING MODE
When used with Novak rock crawling brushless motors, the Crusher can operate in instant-reverse or Crawling Mode. This mode has proven to be a favorite among brushless rock crawlers and offers unique braking and forward/reverse operation that has no reverse delay, which allows instant reverse! This mode also features Novak’s exclusive powered hill/hold/drag brake when used with a Novak crawling motor. The powered hill/hold/drag provides the strongest automatic neutral point brakes to date. This means even the heaviest of vehicles will hold on the steepest of inclines. The 100% pure sensor-based design ensures ultra-fine, low speed control, and non-stop torque throughout the throttle range.
EXTREME SPORT MODE
When used with standard Novak brushless motors (or Novak crawling brushless motors) the Crusher is a full-featured bashing ESC for 2S, 3S, or 4S LiPo setups. The Crusher is not your typical bashing ESC with limited settings, lock out modes, or slimmed down construction. The Crusher is based on Novak's pro race-level ESC platform, and has complete onboard adjustability with fan favorite default settings. The Crusher is suited for normal sized 540 motors, and will handle the larger 550 motors with ease as well.
Product Highlights:
  • Rugged performance ESC for 2S, 3S and 4S rock crawling, rock racing, trail hauling, short course and non-racing “go-fast” setups
  • Durable ESC design with sealed case, included fan, and replaceable wire
  • Auto-detect LiPo Cutoff and ESC Thermal Overload Protection
  • Novak RPM Boost Timing™— Dynamic Timing Advance for increased RPM
  • Complete onboard programming -- Nothing extra needed
  • Novak’s Power Hill/Hold Brakes for extreme holding power in crawling applications
  • Novak X-Drive™ firmware for unmatched throttle response and control
  • Heavy-duty built-in 5A BEC
#1833 - Crusher Sensored Brushless ESC 2S-4S - $235
#3258, #3259 - Crusher Rock Crawler Brushless System (18.5T, 21.5T) - $330
#3257 - Crusher Extreme Sport Brushless System - 17.5T - $330
Available September 2013
Trevor “Chilly” Duncan
Online News Editor
Radio Control Car Action
trevord@airage.com
rccanews@airage.com
http://www.rccaraction.com
Old 08-05-2013, 07:35 PM
ta_man ta_man is offline
This post just mentions a "Heavy-duty built-in 5A BEC" but the info on Novak's web site says it is baed on linear regulator. So that means if you are running 4S and pulling 5 amps out of the linear regulator, the regulator has to dissipate 50 watts of heat ( (16-6) * 5 -> Voltage drop over regulator times current).
I have a soldering iron that gets to 900 degrees on 45 watts. This ESC should really have a switching BEC, not a linear BEC.
The Following 2 Users Say Thank You to ta_man For This Useful Post:
packhntr (08-05-2013), rccardude04 (08-05-2013)
