Old 09-06-2013, 02:51 PM
Chilly Duncan's Avatar
Online News Editor
Kyosho Ultima RB6 Readyset
Latest from Kyosho:
The new Ultima RB6 (readyset) is the latest in the Ultima line of vehicles, which is a further development of the breed. Anodized aluminum chassis with angled sides 2 motor layout setup compatible Proven high efficiency transmission system Readyset is equipped with a rear motor configuration for stability and easy driving characteristics. Big Bore Composite Shocks Team Orion Vortex R10 Sport ESC Team Orion NEON ONE 2700KV motor New high response and torque KS201 servo Adjustable turn buckles Kyosho high traction micro pin tires High down-force “Blade” cab forward body (pre-painted) Step 2.0 M rear wing 100% parts compatible with the Ultima RB6 Kit version Optional parts are already available
What is a Ready Set? A Readyset is a fully assembled model that includes nearly everything you need to run. Body Color scheme is complete so only consumables like batteries and 7.4v Li-Po* are required so you can start operating the model without delay.
Ready Set Contents
  • Factory assembled chassis
  • Pre-painted body
  • 2ch Syncro 2.4Ghz Radio System
  • 1 KS201 Servo
  • Instruction manual
Required for Operation: 4 AA Battery for Transmitter 1 Battery with Deans type plug (7.2v Ni-Mh, 7.4v Li-Po) Charger for car battery Technical Data: Scale: 1/10 Length: 395mm (15.5in) Width: 249mm (9.8in) Height: 140mm (5.5in) Wheelbase: 285mm (11.2in) Gear Ratio: 8.45:1
30858B - $$449.99
Trevor “Chilly” Duncan
Online News Editor
Radio Control Car Action
