Old 10-14-2013, 10:01 PM
Chilly Duncan's Avatar
Online News Editor
Racers Edge PRIME Power Supply
Latest from Racers Edge:
Racers Edge has released the newest addition to the PRIME product family, the PRIME 30amp Switching DC Power Supply. This new model delivers an amazing amount of energy for its compact size, and the stylish red anodized aluminum case with built in cooling fans ensures temperatures are minimized. The dual output ports allow you to power up more than one device at a time without an external distribution box. There are also two independent USB charging ports for portable electronic charging at 5v-1amp per port. A bright backlit LCD screen allows you to monitor the output voltage range, and the 540 watt output allows plenty of voltage to spare for one or more high-charging DC devices. The PRIME 30amp is the ideal complement to the Racers Edge line of PRIME DC Battery Chargers, including the TWIN 400 2x200 watt Dual Port and CUBE 200 4x50 watt Quad Port models. Full specs are as follows:
Voltage: 100-240V AC
Input AC Frequency: 50-60Hz
Output Voltage: 12-18V DC ± 0.5V
Output Current: 30A ± 1A
Current Overload Protection: =31 500MS
Input Fuse: 10A Fuse
LCD Display: Voltage Precision ± 0.3V, Current Precision ±0.3A
Output Voltage Ripple: <150mV
Power Efficiency: 89%
Power Factor: >0.98
Over Temperature Protection: <65°C
Cooling Method: Cooling Fan
Operating Temperature: 0-40°C
Operating Humidity: 0-90%
Dimensions: 218(w) x 139(h) x 59.5(d)
Net Weight: 1.62kg
Visit racers-edge.com or contact your local dealer to order.
Trevor “Chilly” Duncan
Online News Editor
Radio Control Car Action
trevord@airage.com
rccanews@airage.com
http://www.rccaraction.com
