Old 10-23-2013, 10:25 PM
Chilly Duncan's Avatar
Online News Editor
Pro-Line October 2013 New Releases
Latest from Pro-Line:
Pro-Spec Shocks (Front) for Short Course Front
This is a pair of Pro-Line Front Pro-Spec Shocks (kit form). The next generation of Pro-Line Shock Technology has arrived: Pro-Line Pro-Spec Shocks! Every last detail has been refined to give you the best performing and best looking Shocks ever made. The Pro-Spec Shocks are a 12mm Big Bore design with a Single Low Friction X-Ring Seal. The Pistons and Shaft Guides are made from Silky Smooth White Delrin for Low Stiction and the 3.5mm thick Shock Shaft is Hard Chrome Coated, just like full scale racing shocks.
The Pro-Spec Shocks feature an easy access Bleeder Cap Screw for consistent shock builds every time. Each pair of Pro-Spec Shocks includes 3 different piston options (1.4, 1.6 & 1.8) and a blank piston for drilling to a custom size. Custom Shock Tightening Tools and optional shock limiters are also included. Pro-Line’s new Pro-Spec Shocks come in kit form with build instructions, so you can build the shocks exactly how you want. Optional Pro-Spec Springs are available separately. Upper and lower shock pivot balls are included so you can fit a wider range of vehicles right out of the box.
Experience the Performance of Pro-Line’s Next Generation Shock Technology for yourself – Get Pro-Spec
#6308-00
Pro-Spec Shocks (Rear) for Short Course Rear
This is a pair of Pro-Line Rear Pro-Spec Shocks (kit form). The next generation of Pro-Line Shock Technology has arrived: Pro-Line Pro-Spec Shocks! Every last detail has been refined to give you the best performing and best looking Shocks ever made. The Pro-Spec Shocks are a 12mm Big Bore design with a Single Low Friction X-Ring Seal. The Pistons and Shaft Guides are made from Silky Smooth White Delrin for Low Stiction and the 3.5mm thick Shock Shaft is Hard Chrome Coated, just like full scale racing shocks.
Experience the Performance of Pro-Line’s Next Generation Shock Technology for yourself – Get Pro-Spec Shocks!
#6308-01
Sling Shot 2.2″ Sand Tires for 1:10 Buggy Rear and 1:16 E-Revo® Front & Rear
This is a pair of Sling Shot 2.2” Paddle Tires. The newest form of fun is here with the release of the all new Sling Shot 2.2″ paddle tire for mini E-REVO® trucks and 1:10 Buggies. The Sling Shot provides hours of fun in the sand, snow or even in the occasional mud pit. The 12 paddle design ensures maximum performance due to the true scoop design coupled with low roll outer sidewalls. The Sling Shot comes complete with foam inserts and big Pro-Line fun!
#10101-00
Pre-Cut Flo-Tek Clear Body for PRO-2 SC, Slash®, Slash® 4X4, SC10, XXX-SCT, Ten-SCTE, Ultima SC and Blitz
This is a Pre-Cut Flo-Tek Clear SC Body. Pro-Line is pushing the limit of body development by providing a Pre-Cut Short Course body to get you to the track faster than ever before! All of the wheel wells have been cut out for you, including the difficult front and rear air vents. The first Pro-Line body to receive this treatment is the Flo-Tek body: Introducing the first SC body specifically designed to minimize the short-course body parachute effect! If you have ever raced or bashed a short-course truck, you know that SC bodies act like parachutes when going over jumps, causing you to lose control and crash. Pro-Line’s new Flo-Tek SC body features futuristic styling coupled with large vent holes that allow air to flow through eliminating aerodynamic drag. The locations and size of the vents were designed to maximize air flow through the body while keeping the aggressive and high-tech look. Don’t get caught in the wind while the competition passes you by – Get Pro-Line’s new Flo-Tek SC body today!
#3355-17
Pre-Cut EVO SC Clear Body for PRO-2 SC, Slash®, Slash® 4X4, SC10, SC10 4X4, 22-SCT, XXX-SCT, Ten-SCTE and Ultima SC
This is a Pre-Cut EVO SC Clear Body. There is nothing worse than getting arm pump when you are trying to cut out a Pro-Line EVO body. Well, Pro-Line has you covered by offering the EVO body pre-cut. Pro-Line is pushing the limit of body development by providing a Pre-Cut Short Course body to get you to the track faster than ever before! All of the wheel wells have been cut out for you, including the difficult front and rear air vents. It is time to Evolve your Short Course truck into a true race machine with Pro-Line’s all-new EVO SC body! After years of developing race winning bodies for Short Course trucks with advanced aerodynamic features, Pro-Line is ready to unleash the next Evolution of performance bodies!
The EVO SC body is designed with an aggressive sloped nose which keeps as much air as possible from getting under the hood; this decreases the dreaded parachute effect and gives you more control of your SC truck. The improved front down-force also enhances steering for quicker lap times. Pro-Line incorporated the maximum amount of vents possible in the rear of the body, while still maintaining long-lasting durability, in order to reduce drag, rear lift and weight as much as possible. All of these features add up to the most advanced Short Course Race Body ever constructed. If you want to stay on the top step of the podium you must Evolve with the EVO SC Body!
#3413-17
Phantom Clear Body for Tamiya 201XR/XM and Kyosho RB6
This is the Phantom Clear Buggy Body. A brand new body style has hit the scene from the mind of Pro-Line driver Lee Martin: the Phantom. Featuring an all-new cab forward look and sweeping body lines that flow back to a single point, the Phantom has the style and performance you have been looking for. The optional center fin adds additional high speed stability and finishes off the design of this fresh looking 1:10 Buggy body. Lee Martin used the Phantom to finish 2nd in the World at the IFMAR World Championships on the Challenging Silver Dollar track in Chico, California. Now you can own the same winning body style as Lee Martin!
To see what Pro-Line Drivers Ty Tessmann and Lee Martin have to say about the new Phantom body check out the video
#3416-00
Pre-Cut Pro-Line Stabilizer 6.5″ Wing 6.5″ 1:10 Buggy Clear Wing (1 pc)
This is a Pre-Cut Pro-Line Stabilizer Wing. Pro-Line is pushing the limit of wing development by providing a Pre-Cut 1:10 Buggy Wing to get you to the track faster than ever before! All you have to do is set the wicker height to your liking and mount the wing to your buggy. Pro-Line’s Stabilizer Wing combines everything that serious buggy racers are looking for: Performance, Style & Durability. From the moment that you put Pro-Line’s new wing on your buggy you will be amazed at the increase in rear traction and high-speed stability. The Stabilizer Wing features a stepped side wing profile to clear the rear tires but also adds much needed durability. Speaking of durability, buggy wings take a beating with each crash so Pro-Line made the Stabilizer Wing out of super thick Genuine Lexan. Get to the top step of the box faster than ever with Pro-Line’s new Pre-cut 6.5” Stabilizer Wing for 1:10 Buggy!
#6247-17
Pre-Cut Pro-Line Stabilizer 7″ 1:10 Buggy Clear Wing for 1:10 Buggy
This is a Pre-Cut Pro-Line Stabilizer Wing. Pro-Line is pushing the limit of wing development by providing a Pre-Cut 1:10 Buggy Wing to get you to the track faster than ever before! All you have to do is set the wicker height to your liking and mount the wing to your buggy. Pro-Line’s Stabilizer Wing combines everything that serious buggy racers are looking for: Performance, Style & Durability. From the moment that you put Pro-Line’s new wing on your buggy you will be amazed at the increase in rear traction and high-speed stability. The Stabilizer Wing features a stepped side wing profile to clear the rear tires but also adds much needed durability. Speaking of durability, buggy wings take a beating with each crash so Pro-Line made the Stabilizer Wing out of super thick Genuine Lexan. Get to the top step of the box faster than ever with Pro-Line’s new Pre-cut 7” Stabilizer Wing for 1:10 Buggy!
#6248-17
Blockade X3 (Soft) Off-Road 1:8 Buggy Tires (Mounted) for Front or Rear, Mounted on Lightweight Velocity White Wheels
This is a pair of Pre-mounted Blockade X3 Tires. Pro-Line’s extremely popular Blockade tire in X3 compound is now available Pre-Mounted! Historic. Revolutionary. The Best. Just a few words that have been used to describe Pro-Line’s new Blockade tire. History was made the first time the Blockade touched the race track – Winning the 2011 ROAR Fuel Off-Road Nationals by 2 laps! Now available in the X Series Compounds and mounted to Velocity Lightweight wheels! The Revolutionary tread design features large lugs for class leading tread life, perfectly balanced tread spacing for maximum forward bite and uniquely blended side tread that reduces the edginess found in other race tires. This tire will give your buggy qualifying speed with tread life capable of handling hour long A-mains. Pro-Line’s Blockade is the new must-have 1:8 Buggy Race tire and will dominate your local track. The Blockade – The latest way that Pro-Line is Racing to Bring You The Best!
Pro-Line makes using performance tires easier than ever by offering the Blockade X3 tires mounted on Velocity Lightweight wheels. Pro-Line lives and breathes the philosophy of Racing To Bring You The Best and that is exactly what the Lightweight Velocity 1:8 Buggy wheel represents. Pro-Line engineers worked tirelessly to create the lightest possible wheel without compromising strength to give your buggy the lowest rotating mass and the fastest acceleration ever achieved. The lighter wheel also has a slightly higher level of flex which results in more traction in loose track conditions. The new Lightweight wheel is marked with Pro-Line’s latest P-L logo giving your buggy the best possible look that matches the performance.
If you are ready to bring your buggy to the next level, get a set of Blockade X3 Tires mounted on Lightweight Pro-Line wheels!
#9039-033
Bow-Tie 2.0 X3 (Soft) Off-Road 1:8 Buggy Tires (Mounted) for Front or Rear, Mounted on Lightweight Velocity White Wheels
This is a pair of Pre-mounted Bow-Tie 2.0 X3 Tires. Pro-Line’s extremely popular Bow-Tie 2.0 tire in X3 compound is now available Pre-Mounted! Pro-Line’s original Bow-Tie took the 1:8 Buggy racing World by storm winning the 2006 IFMAR World Championship and countless National Championships. The Bow-Tie is back stronger than ever as the Bow-Tie 2.0! The Bow-Tie 2.0 tire received a complete overhaul with the latest generation Race Tire carcass and enhanced side pin tapering designed to smooth out the steering and not catch the ruts. The Bow-Tie’s signature tall, horizontal, Bow-Tie shaped Tread remains intact along with the incredible traction that everybody loves from the Bow-Tie. The Bow-Tie 2.0 is now available in Pro-Line’s new High-Speed and Long Wear European style X Compound so you can run exactly what Team Pro-Line used to take on the very best drivers at the IFMAR World Championships!
Pro-Line makes using performance tires easier than ever by offering the Bow-Tie 2.0 X3 tires mounted on Velocity Lightweight wheels. Pro-Line lives and breathes the philosophy of Racing To Bring You The Best and that is exactly what the Lightweight Velocity 1:8 Buggy wheel represents. Pro-Line engineers worked tirelessly to create the lightest possible wheel without compromising strength to give your buggy the lowest rotating mass and the fastest acceleration ever achieved. The lighter wheel also has a slightly higher level of flex which results in more traction in loose track conditions. The new Lightweight wheel is marked with Pro-Line’s latest P-L logo giving your buggy the best possible look that matches the performance.
If you are ready to bring your buggy to the next level, get a set of Bow-Tie 2.0 X3 Tires mounted on Lightweight Pro-Line wheels!
#9045-033
Big Blox X3 (Soft) Off-Road 1:8 Buggy Tires (Mounted) for Front or Rear, Mounted on Lightweight Velocity White Wheels
This is a pair of Pre-mounted Big Blox X3 Tires. Pro-Line’s extremely popular Big Blox tire in X3 compound is now available Pre-Mounted! Introducing the Ultimate Long Wear tire – Pro-Line’s Big Blox. Customers and Racers continue to demand higher and higher performance out of 1:8 Buggy Race tires while also requiring tires that last longer and longer. After much consultation and input from top-level Pro-Line drivers both in the U.S., Europe and across the Globe, Pro-Line has developed the Big Blox Race Tire to meet these lofty expectations. Large center lugs formed into a grid pattern provide the base for the long wear characteristics and unmatched mechanical grip found by all test drivers. The Big Blox tire also pays homage to Pro-Line’s rich racing heritage with Bow-Tie shaped lugs that scoop the Earth and propel your Buggy to the top step of the podium. Great care was taken in detailing the side tread to achieve the same smooth side bite and steering feel found in Pro-Line’s highly successful Multi-time National Champ Blockade Race Tire. The Large Lugs on the Big Blox allow racers to choose softer compounds than previously possible while still lasting through long A-Mains. Step into the Big Time with Pro-Line’s Big Blox now available in Pro-Line’s new High-Speed and Long Wear European style X Compound. Now you can run exactly what Team Pro-Line used to take on the very best drivers at the IFMAR World Championships!
Pro-Line makes using performance tires easier than ever by offering the Big Blox X3 tires mounted on Velocity Lightweight wheels. Pro-Line lives and breathes the philosophy of Racing To Bring You The Best and that is exactly what the Lightweight Velocity 1:8 Buggy wheel represents. Pro-Line engineers worked tirelessly to create the lightest possible wheel without compromising strength to give your buggy the lowest rotating mass and the fastest acceleration ever achieved. The lighter wheel also has a slightly higher level of flex which results in more traction in loose track conditions. The new Lightweight wheel is marked with Pro-Line’s latest P-L logo giving your buggy the best possible look that matches the performance.
If you are ready to bring your buggy to the next level, get a set of Big Blox X3 Tires mounted on Lightweight Pro-Line wheels!
#9048-033
Trevor “Chilly” Duncan
Online News Editor
Radio Control Car Action
trevord@airage.com
rccanews@airage.com
http://www.rccaraction.com
Old 10-24-2013, 08:17 AM
packhntr packhntr is offline
Nice, wing, tires and shocks. Body not so much.
The Following User Says Thank You to packhntr For This Useful Post:
T3GT (10-29-2013)
Old 10-30-2013, 02:27 PM
Online News Editor
Sling Shot 2.2” Paddle Tires video added to the original post.
Online News Editor
trevord@airage.com
rccanews@airage.com
The Following User Says Thank You to Chilly Duncan For This Useful Post:
packhntr (10-30-2013)
Old 10-30-2013, 06:07 PM
andystoybox's Avatar
andystoybox andystoybox is offline
Is there a way to get the Phantom body precut from the beltline up? That way it can be taken off, turned around and put back on with shoe goo the correct direction and get the cab back where it belongs. Otherwise it's a huge waste of lexan on another ugly body under the pretense that it will improve performance.
