  #1276
Old 12-28-2008, 12:28 AM
Killerush Killerush is offline
Originally Posted by Daddimike View Post
what do you use for motor mounts on this .12 in the Rush?
I use Team Associated RC10GT mounts, but HPI makes the same mounts for the RS4. I'll send you my address today and get my wife to pack up the .12.
Old 12-28-2008, 12:51 AM
BullyDawg BullyDawg is offline
Do you guys know what engines bolt in directly on the stock mounts?
Old 12-28-2008, 02:06 AM
If I remember correctly the original Rush engine had integral mounts and the Evo will accept any small block (.12-18). It's been a while since I messed with mine so I can't recall if I actually used the RC10 mounts or I used the factory Evo mount.
Old 12-28-2008, 03:26 AM
Daddimike Daddimike is offline
the stock 15fe had the mounts cast into the block, if you use another engine then you neef to find mounts for those
Old 12-28-2008, 01:12 PM
Okay, so what motors will work with what motor mounts?
Old 12-28-2008, 05:02 PM
You can get the HPI aluminum heat sink engine mount for like 30 dollars I think. They work just fine. There are two types, one for pull start motors and another for non pullstarts.
Old 12-28-2008, 05:03 PM
Killerush are you on?
Old 12-28-2008, 07:47 PM
I am now.
Old 12-28-2008, 08:15 PM
Hows the weather over there?
Old 12-28-2008, 08:33 PM
It's a little cool and ALWAYS windy. It would be nice if the wind would ever calm down.
Old 12-28-2008, 08:35 PM
quite a while ago I purchaed some Masher 2000 tires on some rims. The rear were 12mm hex's and the front were not so I figured they would work. Once I got them I realized that they would not fit on my stock front Rush spindles. So I went ahead and got some Traxxas steering knuckles in hopes that they would fit, and sure enough they did. That was a taxing lil adventure. I am having a hard time getting my hump pack into the battery box of the Rush. Any suggestions? Anyone? Killerush, what were you telling me was a direct drop in for the transmission?
Old 12-28-2008, 08:39 PM
you out on the water most of the time? What do you do?
Old 12-28-2008, 08:45 PM
I believe there are only two type of motor mount small block and big block, but not all small block mounts will fit in all small block vehicles
Old 12-28-2008, 09:14 PM
I run my hump pack in front of the front shock tower. I removed the rear battery box and relocated the battery for more front grip. It has worked very well on my setup.
Old 12-28-2008, 09:29 PM
between the front shock tower and body posts? Was that the RS4 differential for the transmission? Got a link or picture of it by any slim chance?
Old 12-28-2008, 09:52 PM
I have a 5 cell hump pack, it fits nicely in front of the shock tower and I use zip ties to hold it in place. The RS4 diff gears will fit in the Rush, not the tranny. Sorry no pics.
Old 12-28-2008, 09:55 PM
Yeah I have the 5 cell hump as well, I will have to check out that mounting tip for sure though. I also have the RS4 spider gears in there. I was thinking you were talking about something else.what is it Tuesday morning there?
Old 12-28-2008, 10:11 PM
It's Monday, a little after noon. I changed the gears in mine after the first break-in tank, that's when I found out the original spider gears were plastic. I am also running the RS4 bevel gear, which is geared a little differently than the stock Rush gear if I remember correctly.
Old 12-28-2008, 10:16 PM
See I thought you were talking about this here http://http://cgi.ebay.com/HPI-A435-...3286.m20.l1116 not the gears, thats why I was shocked. I tried that mounting tip for my battery. Looks like it will work nice. Give me some room in the back to fabricate some wheel bar plate.
Old 12-28-2008, 10:26 PM
I moved mine out of necessity. In tight turns I couldn't get on the throttle without chattering the front tires and developing a push. Once I moved the battery I can stay in the trottle in the middle of a turn. The only down side was I lost a little bit of punch coming out of the turns due to wheelspin because of the lost weight in the rear. But it is still faster per lap.
Old 12-28-2008, 10:36 PM
do you do paypal?
Old 12-28-2008, 11:26 PM
I'm not sure if my account is still active. If you want to do a money order that's fine with me. I'll check my acct and shoot you a pm.
Old 12-30-2008, 01:13 AM
I got my Rushes today. One is a roller and one is completish! Pictures to follow...
Old 12-30-2008, 01:20 AM
NIce I would love to see them.
Old 12-30-2008, 04:06 AM
I spent all day getting one all modified, and all set up. All I need are crystals and to get the engine running. I couldn't get it going at all. It would get hard to pull where it was about to start, it would do it for days and not start. Anyone know the stock carb settings?
