  #926
Old 07-19-2005, 09:40 AM
Mika Mika is offline
Sinclair, the stock 2-speed is crap. It will break when you tune your engine for max power. At least, it broke easily w/ a Novarossi Race .12
I even broke the FZW56 (the finger of it) with OS RX 15 after couple of gallons. Good Luck!
I had never any problems with the brakes, brakes are great in fact. Are you sure your servo is strobng enough? I always used the stock steel brakes with pads on calipers.
The diffs will last if you fill in them with thick silicone oil and seal them with silicone sealant. If you don't seal including the screw holes the silicone oil will pour out. But when you do that that difference is huge! And diffs will last. Use thicker oil in front and less thick at rear.
And oh yeah, the car looks nice!
Old 07-20-2005, 07:11 AM
maxxx_revv maxxx_revv is offline
ok, I just started in nitro cars and I was impressed by the 35mph it packed compared to the hopeless electric ones I have seen, but then again mine was fairly cheap next to everything else.
I still have to try it out on a track though, only revved it up and down a dead end road and making the neighbours angry lol.
Old 07-20-2005, 07:13 AM
oh yeah - my car also has a porsche chassis but it looks nowhere near as nice as that (it's like a rally car with ads all over)
Old 07-20-2005, 05:44 PM
Siclair Siclair is offline
Glad you guys like the body. It's a HPI super nitro body and fits perfectly. The only modifications I had to do were to reinforce the wing mounts and relocate the body mounts. Take an old sock or something similar and drench it with epoxy, works just as good as fibre glass.
Well Mika, we both know the FZW56 is more durable than the stock 2-speed. But I've had no problems so far and as I wrote earlier I've run 6,5 litres and I’ve been driving hard.
I disassembled the 2-speed today since I changed the two spur gears and pinion gears, going for more top speed. I’ve surely got enough HP with the TZ. I found one small problem though; the cam is a bit worn out where the small pin goes thru the transmission shaft, a glitch but nothing more.
I’m curious, how come I’ve had such success with the stock 2-speed? It has a plastic bell indeed but where the cam lever engages there is a small metal pin (like the one I described above) and it’s still holding. And believe me, I know how to tune an engine. When I get the chance I’ll take some photos of the old 2-speed.
About the differentials. I’m currently using super adhesive grease (not the cheap hobby grease included) with the bevel gears and as I wrote earlier there is now wear to talk about. As long as you pack it almost full of grease it’s just as good as silicon oil.
I get the feeling people just don’t know how to align the pinion gears with the spur gears. I also regular clean all the parts.. And by cleaning I mean taking it apart and lubricating every part that needs to be lubricated.
From what I’ve read I assume you are pretty experienced Mika, so I’m not insinuating that you don’t know what you are doing.
Old 07-21-2005, 01:18 PM
Sinclair, I'm glad your 2-speed is still holding on. Maybe I just was unlucky. But it was one take off that was too much for it, the finger went through the plastic.
After doing my diffs (filling silicone oil and sealing them sealant) I never had to take them apart. I did couple of times though, but both times I realized it was really unncessary. And with those the car was running great. Don't have the car (two of them in fact) anymore. Afterwards I tried HPI Super which was also very nice. Since then I have moved to 1/8 buggies and racing.
Old 07-21-2005, 04:18 PM
Has anyone managed to fit foam tires? If so, what tires?
Old 07-22-2005, 04:25 AM
To the older SuperTen yes, with the smaller axle/hex, but to the FW04 no. I don't think you can find suitable foam tires anywhere... After all, rubber tires work much better on it.
Old 07-23-2005, 04:20 AM
jakestreats jakestreats is offline
Hi All here is the link to Ebay for foam tyres for the fw04 ,thanks
HPI Super Nitro RS4 BLACK MESH Complete Foam Tire Set ! Item number: 5988856445
jake
Old 07-23-2005, 03:46 PM
Basically HPI Super Nitro tyres do not fit SuperTen FW04 (FW03 only), like I said the axle/hex is not ther same size.
I'm surprised if these fit even they say " Kyosho’s SuperTen FW04 as well!"
Have you tried these? If they do that's good news.
Old 07-25-2005, 09:00 AM
HI i will check to night to make sure.jake
update, just looked at the pictures on my website and yes i have only fitted them to the superten and not to the fw04 sorry about that guys thanks
Old 07-25-2005, 12:35 PM
that's what I said. thanks
Old 08-10-2005, 07:14 AM
markanda markanda is offline
funny thing is that I just saw those tires listed again on ebay !!!
Old 08-10-2005, 11:02 AM
they fit previous model of superten
Old 08-23-2005, 07:10 AM
hey havent been on in a while. Internets been down.
I'm going to completely pull apart my car and clean the whole thing. I just been doing heaps of drifts in my backyard around tires, and in two tanks the air filter was so clogged the car was going about a quarter speed at full throttle.
So i'm going to clean it. Also, as it's fully stock i'm gonna go and get lots more air filters, a couple of spare glow plugs, a two-speed clutch, better tires and better suspension. Also i'll buy anything else that makes it better, i can afford and i want.
Old 09-03-2005, 10:31 AM
hi has anyone ever seen one of these ,
Kyosho Cup Edition Superten Kit. Kit number 31151
many thanks
Old 09-03-2005, 02:07 PM
many thanks
You must have seen that one on ebay.....I know ...it comes strictly rolling chassis and with the high performance two speed. I was thinking of getting it but was able to purchase the two speed (NEW) for ninety bux. I was going to get it too. I am looking for the superten II (four stroke edition). I have a brand new Four Stroke OS 26 fc I am lookng to sell.
Old 09-07-2005, 12:12 PM
hi does anyone have a crank and other bits to convert a fs26 4 stroke engine to a pullstart engine ,thanks
Old 09-15-2005, 09:54 AM
filow_bedow filow_bedow is offline
Has anyone seen in north america a 3 speed conversion for 4 stroke fw-03 cars? i know it exists, i am just trying to locate one. It is made by Form racing in japan.
thanks.
Old 09-15-2005, 09:59 AM
Hi Dan
where did you purchase those shocks? are they made by kyosho?
thanks,
Chris.
Old 10-05-2005, 01:55 PM
Dan H's Avatar
Dan H Dan H is offline
Sorry for the late reply. Yes, they are Kyosho and off the Phantom 1/8th onroad car from a few years ago.
Old 10-05-2005, 01:58 PM
Dan H's Avatar
Update: With new Kyosho distribution, I was able to get my new clutch in pretty fast at my LHS. The 4 stroke will see action soon once again!
Old 10-05-2005, 07:36 PM
Now that Great Plains is not with KYosho anymore and with the formation of Kyoshoamerica, that explains it all. Now we need them to bring the fw-04 back to the US !
Old 10-24-2005, 08:13 AM
C0NTENDER C0NTENDER is offline
I know this isn't the correct forum, but I thought I would give you guys in this thread first dibs. I have a unpainted McLaren body that I can't use. Anyone (PM me if interested)
Old 10-25-2005, 11:16 PM
mdbeachy mdbeachy is offline
Contender, your pm is full. I'm interested in it pm me.
Old 10-26-2005, 03:58 AM
Dan H's Avatar
If he doesn't take it, I'm interested.
