  #176
Old 07-09-2003, 10:55 PM
Enrique.v Enrique.v is offline
Originally posted by darkangel
I thought of that, but wanted to go rechargeable so I can save a little money on batteries. Mounting them might be more of a hassle then it's worth.
? They are rechargeable...
Havent Built the car yet. But they should fit, I'm thinking 2x2x1
Old 07-09-2003, 10:58 PM
darkangel darkangel is offline
Pretty nice track. Ours is temp., so we have to set it up on every race day. I don't mind, at least the track changes, some-what. Always a long back straight into a sweeper. That's what we get for playing with 1/8 scales.
Old 07-09-2003, 11:03 PM
2x2x1? I think that's a bit big. The battery casing is something like, 2. x .75 x 1.25. I ended up using the Team Orion 1100 mah micro pack, and moving one battery so they are in straight line. Perfect fit.
Old 07-09-2003, 11:39 PM
Just like those little dots i placed in the top post i made.
I'm not sure if iam going to use that gas tank..But making a new RX batt mount should make the batts fit.
Old 07-09-2003, 11:50 PM
Oh yea, there is enough space from the pics i saw on the 1st page of the thread.
Old 07-11-2003, 07:24 PM
Garen or Kawadakid,
Any word on a front one-way and a solid rear? Just being curious
Old 07-15-2003, 12:12 PM
garen garen is offline
Front one ways are on their way, should be in the States very soon.
I don't know if a rear solid axle will be made available. We tested with a solid rear and our results are mixed. You can easily make one out of the diff in your car, email me to find out how.
Old 07-20-2003, 12:54 PM
crackerjack crackerjack is offline
Two Questions
1. Does anyone use an AMB personal tansponder? If so, can you post a pick of where you mount it?
2. This pivot ball suspension is new to me. I understand that you use the clips so that you know that the balls are set equal on both sides, but do you still need a gauge to set everything up? For example, if I have a 2mm camber clip in the bottom front and a 1mm clip in the top, how do I know how many degrees of camber I have?
Old 07-20-2003, 10:15 PM
I just got my AMB transponder today. I mounted it inbetween the front uprights with the cord going through the front shock tower and underneath the sway-bar.
I tried using the camber clips, but they kept on falling off. Just be sure to keep both sides equal (use a ruler or caliper). Hudy, Integy, and Fioroni all make decent set-up fixtures. Don't have one yet but will in near future.
Old 07-21-2003, 12:32 PM
You can tape or glue the AMB to the side of your throttle servo. You can also purchase a AMB mount from Team Jibroni (sorry don't have the info with me). This mount clips to the existing mount and holds the new AMB's in place.
You do not need a gauge if you use the clips, but you should have at least a cheap camber gauge (RPM, etc.) Set your front camber so that the tires wear flat, often there is no need to measure the camber. Set the toe in the rear using the clips, and again, set the camber so that the tires wear flat. You can get a setup gauge to check the rear toe, but again, set it so that you have enough rear grip.
These clips should not fall out, if they are you are doing something wrong....don't tighten the pivot balls so that they squeeze the clips out of place.
Old 07-21-2003, 02:41 PM
Garen - thanks for the info on the transponder mount. I'll look for one. As far as the camber clips, how do I know how much camber each clip will give me, or is it trial and error.
Old 07-21-2003, 06:32 PM
KawadaKid KawadaKid is offline
your best bet is to get a camber gage. The RPM one is good and is no more than $10. Use the clips on the bottom piviot balls just to make sure the cars width is even on both sides, then use the gage to check your camber.
Old 07-21-2003, 07:48 PM
Thanks - That's what I thought would be the easiest. I already have the gauge, so that will work. Like I said, this pivot ball stuff is new to me.
Old 07-22-2003, 12:51 AM
Piviot balls can be confusing at first, but you will love them.
Old 07-22-2003, 05:42 AM
rcabj rcabj is offline
thrust bearing?
1. if the thrust bearing is still in place ( i mean all the small balls) is still intact , is it considered still okay, and
2. if its ok...does the wearing out of the washer( inside and outside off the bearing effects the performance..?
u see i am having problem the 2 speed enganging pretty quickk....from my past experience 2 things that causes the quick shifting is either broken thrust bearing or the spring tension inside of the 2 speed ishifting no longer good. got to change to new spring.
thanks.....
hmmm...whose the driver....
Old 07-23-2003, 10:48 PM
Well, I finished putting my Pro together tonight. The only thing I have left to do is cut the mounting and cooling holes in the body. Hopefully I'll be able to start breaking it in tomorrow.
Here's a pic of the body.
[IMG]http://www.******.net/view_single.php?medid=7109[/IMG]
I think it turned out OK for a can job.
Old 07-24-2003, 08:45 PM
Team Jibroni email: ddprecision@aol.com
I don't know what else they make other than the personal transponder mount.
Old 07-26-2003, 12:13 AM
still on thrust bearing
any tips for long life of thrust bearing.
Old 07-28-2003, 12:12 PM
If the thrust bearing balls are in place, the bearing is likely still good. I don't know what you can do to the clutch to make the thrust washers wear out. I have never experienced poor shifting because of the thrust bearing going bad.
Keep the thrust bearing greased, leave a little play for the clutchbell, and you'll be fine.
Old 08-04-2003, 02:56 PM
Clutch Problems
First, My clutch was engaging almost immediately, and then it wouldn't disengage. Now, it engages properly about 2-3 times then starts to slip. I've been told that the centax style clutches need to "break in", but I feel like I'm chasing the setting around. Anyone have any suggestions?
Old 08-04-2003, 03:36 PM
i haven't any problems with mine. what spring are you using? I'm using the 1.4 mm spring on mine with the adjustment 11.8 mm from the end of the sg shaft. It'll engage about 1/4 throttle every time. never had any problems with it not un-engaging.
Old 08-09-2003, 05:19 PM
Finken Finken is offline
Belt touching manifold
Hi
I have a Novarossi S3, with inline pipe, and
the belt is touching the manifold when mounted????
Anyone else have this problem? And how can i solve it?
Old 08-09-2003, 10:39 PM
The car somes with a belt tensioner. increasing the tension on the belt should eliminate your problem.
Old 08-10-2003, 04:09 AM
I have tightened the belt tesioner
bur it still touches the manifold??
Old 08-10-2003, 12:02 PM
NMT_RACER_BOY NMT_RACER_BOY is offline
it is your inline pipe.
you need one that clears the belt
